Hi, I want to convert a rmvb movie file to a dvd, but this rmvb has 2 language(English, Chinese). How can I extract or convert to only one language wave audio file? can Goldwave do that? how? Thanks in advance...
Should be possible with mplayer using -ao pcm, pan1:1:0 and -channel 1.
-ao pcm outputs to a pcm wav and pan=1:1:0 or pan 1:0:1 should remove either the left or right channel. -channel 1 should output a single mono stream.
No idea if goldwave can open rmvb files or not, but it can definatly do the rest.
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
convert wav to wv
By pcb in forum AudioReplies: 10Last Post: 12th Apr 2009, 13:08 -
Convert X to Y directly or X to WAV then to Y?
By videohalp in forum AudioReplies: 5Last Post: 8th Sep 2008, 02:05 -
How to convert .vob to .wav?
By showmi in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2008, 13:27 -
goldwave and wav codec
By natty in forum Video ConversionReplies: 4Last Post: 15th Jun 2007, 08:57
