Hi all, I have these *.dat files, they are Karoke vcd files, I want to burn to a cd so I can play it in my dvd player and sing. How could I burn it so I would be able to sing the kvcd files. ie. change the audio channels lower so i be able to sing to it.
thanks, appreciated.
Before, I just changed the .dat to .mpg, then use Nero to make the VCD karaoke. I had no problem. But I read the proper way is to use Isobuster or similar software to extract .dat to .mpg for error-free conversion.
If it is a karaoke file, you will be able to sing along with no more additional works. Just make sure Simon Cowell is not listening when you sing
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 06:50 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 06:54 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 07:03
