I have a few .AVIs that I would like to put on a VCD along with a few dozen MP3s. I'd like to have a menu that lets you select between either the videos or goig to a separate menu to select the MP3 songs. This should be able to play on a DVD player. Is this possible? I have Nero (full suite) and TMPGEnc DVD Author but can't get the job done...
Thanks much.
Results 1 to 9 of 9
Well, Well
VCD tracks & MP3 tracks cannot be mixed together.
However if you have TMPGEnc you can do this. Take a still picture as your video source. JPEG or BMP will do. (You dont want to stare at ablank screen). Take your MP3 file as audio source. Select the VCD template and encode. You will get a VCD compliant MPEG file with only one still image for the duration of the audio. Author this file along with your other VCD files to a VCD.
Nero Vision Express will NOT import still image as video.When I was born I was so shocked that I could'nt speak for 18 months. -
I tried your suggestion, but no sound plays when I run the file.
I used TMPGEnc Plus 2.5 to merge a .JPG file with a .MP3 file. The resulting file can be merged into either .MPG or .AVI format, but either way I don't get any sound. Any chance you know what I'm doing wrong? -
Thanks Zippy, works fine now.
One question though. My original MP3 file was roughly 5 Mb. Now that I've had to convert the MP3 to WAV, it's 50 Mb. If my VCD only has about 400 Mb left on it (after adding a music video), I was hoping to fit quite a few MP3s on it, now that every 4 minute song is ~50 Mb, I'll only be able to fit 7-9 songs on the VCD. Any advice? -
TMPGEnc will encode your jpg and wav at the standard vcd bitrates of 1150 kbps for the Mpeg1 video and 224 kbps for the MP2 audio. Your mpeg can be up to 800 MB and will fit a standard CD, giving you up to 80 mins of playing time. You will need to author and burn the mpeg into VCD format, I suggest VCDEasy.
"Art is making something out of nothing and selling it." - Frank Zappa -
You can always use Nero Vison Express and make a slideshow with audio, and you will encode the jpg as still frames at 704x480/576, with better resolution then a video made with TMPGEnc and with only few MB (only the audio track take MBs but it's a normal MPEG1 Layer 2 224Kbps).
I use this system to make this job, but you must have Nero Vison Express, but I think that there are other way, but they are most hard.
The problem with TMPGEnc is that if you encode the video with the audio you will have a real videostream, with Nero Vision Express you will have only still frames and audio.
Issue w/ DV AVIs & DV Date/Time Software
By Anonymous8443434 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 10th Jul 2012, 11:06 -
Burrrn and MP3s
By Fantome in forum AudioReplies: 7Last Post: 16th Dec 2010, 10:25 -
Creating a DVD using VOBS & MP3s
By ZenFrog76 in forum Authoring (DVD)Replies: 4Last Post: 17th Oct 2009, 03:00 -
Selling your MP3s?
By Dr.Gee in forum Off topicReplies: 4Last Post: 31st Jan 2009, 14:31
