  1. I was just wondering if you will be adding dual layer support for svcd2dvd. By that I mean for the autofit feature for avi's. It would be nice if you could choose the regular dvd5 or dvd9 DL when using avi's. When using regular mpg's it's easy to get the correct size for Dual Layer discs beacuse the output size is given in plain english. I know from reading your posts that you don't have a dual layer burner but I don't believe you would need one to add this feature would you? It's not really a big deal right now with the price of DL discs but later on when they become more mainstream and lower in price I can see myself using them extensively. It would be a great little addition to the software. Just my 2 cents. Thanks.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Sounds like a good idea for the autofit to accommodate this.... btw i do have one but have not used any DL media yet!
