I like this drive and I like the reviews but is it possible to change the bitsetting. If yes what is the software needed to change the booktype and what version of that software is the best one to use. Please reply thanks.
If I recall correctly this drive is just a rebadged Lite-ON which does support bitsetting. I would search the Lite-ON forum at cdfreaks.com and find out what those guys are using.
http://codeguys.rpc1.org/firmwares.html
go to the codeguys site you'll find what you need.
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 14:10 -
Change bitsetting on DVD Duplicators?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 14th Sep 2008, 13:58 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 10:21 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 08:41 -
Sony DRU-820A DVD Drive suddenly burning slow
By progrocktv in forum DVD & Blu-ray WritersReplies: 3Last Post: 24th May 2007, 21:55
