My dvd player doesnt play svcds nor can it change pal to ntsc format, so i have to convert the svcd to true dvd format which is a pain. Usually I use Tmpg to join the 2 mpg files, then tmpg to de-multiplex the audio from the video: Then I take the audio file and change it from pal to ntsc with BeSweet also changing the the audio from 44 to 48hz while im in BeSweet. Then I use DVD2AVI to create the .d2v file. Open up Tmpg and select Ntsc Film under Super video-cd and I have it set to CBR standard format {this part im a little confused because i always thought it was suppose to be VBR}. Then I take the .d2v file created and open it with Tmpg and start the conversion from Pal to Ntsc. After it has converted I Simple Multiplax it and I get once again 1 big mpg file with sound and movie. Then I have to De multiplex the audio from the video once more so i can get a .mp2 and a .m2v so I can began Authoring.
The reason for the second de multiplex is because after I change the video to Ntsc with Tmpg it gives me a .mpg file in return. I then have to take the audio and video {both in ntsc now} and multiplax and then demultiplex so i can get the mp2 and m2v files for authoring.
Could i have just simply renamed the .mpg to .m2v since the file was already turned into a ntsc film when converting to ntsc and then just author it?
Im sorry but is it me or am I doing unnecessary steps in the above explanation? The goal was to turn a SVCD or VCD to true Dvd format so my standalone can play the dvd. The second goal was to turn the Pal format into Ntsc.
This is the link with the directions i follow:
https://www.videohelp.com/forum/userguides/166237.php
Also do VCD .m1v files have to be converted to Ntsc Film also or just Svcds?
Thnx for any help and advice you guys can give me.
This guide is much better:
https://www.videohelp.com/forum/userguides/171216.php
Have fun!
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC to PAL-M RF conversion
By ptannjr in forum Newbie / General discussionsReplies: 4Last Post: 10th May 2007, 14:38
