Hi,
I have used ScenalyzerLive to caputure my video. It was producing a avi
file with data rate 3640.62 Kbps.
I have read somewhere that if the data rate is 8 Mbps, then it would really
very good quality video.
I am using the Sony dv output camera. How can I increase the data rate in ScenalyzerLive? or which capturing software is good for doing this?
is it really good audio setting ( 32 KHz ,16 bit Stereo ,pls refer the
image attachement)?
Thanks in advance
Regards,
Anbu.
You(and some tools) are confusing byte with bit. 8 bit is 1 byte.
DV is around 3.6 Megabyte/s and that is around 28 Megabit/s.
DVD is around 3-8 Megabit/s and that is around 0.4-1 Megabyte/s.
So when are you converting the DV AVI to DVD you are reducing the size, lowering the bitrate. -
28 MegaBytes/second for DV.Originally Posted by Baldrick
Hi,
Thanks for the answers.
I have attached the image for the video capturing setting.
Pls let me know is it the best quality capturing?
Regards,
Anbu. -
@mpegencoder:Originally Posted by MpegEncoder
better check that -- original post sounds good to me (about 28-29 mbits/sec including video, audio, and overhead for DV25)George -
Sorry to Baldrick, I misread that.Originally Posted by GeorgeW
avi data rate too high?
By hello2000 in forum Video ConversionReplies: 5Last Post: 3rd Aug 2010, 11:43 -
HDC setting question, 2 pass + manual bit rate
By jsbenson in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 20:15 -
Good CD/DVD data Burner
By Hikari112 in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2007, 20:30 -
Data rate for HD video
By spandau in forum EditingReplies: 3Last Post: 21st Nov 2007, 14:23 -
How total data rate is calculated?
By Netozai in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2007, 16:47
