The purpose of this new firmware will enhance the below main capabilities:
1. Make the subtitle "FONT" clear and easier to read.
2. Make the subtitle show in 2 phrases instead of 3 phrases
3. Add new codec, can read New "Nero MP4" format
4. Can read new DVD-9 formats
I have tested both AAC 2.0 and 5.1 channel Nero Digital with good results.
Dear WesleyHester,
Can you tell me how you encode 5.1 nerodigital mp4 file?
In my testing, this player can only play ASP/Standard.
In the nerorecod2, only the ASP/standard is playable in this
RJTECH 1500DVX-II .
However, there is no 5.1 in ASP/Standard. You can only use stereo aac.
Thanks,
JarJar -
Be careful using this I updated my player, it looked like it was progressing normally then I go a write failed message toward the end, I turned off the player back on and things were dodgy. DVD Playback was skewed and the remote and door close buttons did not work. SO I decided to try again. This time it completed successfuly. I turned off the player then back on, and the unit would not any longer power up. So it's completely Dead now. I cannot find any reset options so I killed the player with this update.
March 6th Sony devices firmware updates contain Cinavia: BEWARE
By kILLDR3n in forum DVD & Blu-ray PlayersReplies: 10Last Post: 10th Mar 2012, 23:33 -
GE DV1 No Firmware Update What Is Up??
By DJboutit in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2011, 23:16 -
Where to Get Firmware Update
By Teac23 in forum ComputerReplies: 1Last Post: 26th Apr 2009, 14:52 -
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 23:46 -
DVR1112D firmware update?
By videobread in forum DVD & Blu-ray WritersReplies: 3Last Post: 15th Sep 2007, 21:02
