the program is great
both at vob/mpeg2 to avi and avito avi
sadly there is supposedly spyware
doom 9 say
"Starting with the AutoGK 1.84 beta, a piece of adware/spyware is installed. If you're using Internet Explorer to surf the web, this component will periodically display ads on your screen based on the content you're currently viewing. You can get rid of this, by uninstalling DAE in the control panel - AutoGK will still work without it. This only concerns AutoGK 1.84, but it might be integrated into upcoming stable releases as well."
http://www.doom9.org/index.html?/autogk.htm
you also need to remove the dae file from C:\WINDOWS\system32 directory
my question
what is the spyware meant to do
i havent noticed it
no pop ups or anything
is this because
1 i run windows firewall
2 i dont use internet explorer
3 i had version 1.6 installed which is spyware free meant that when i installed the new version 1.95 plus 2.01 beta so that avis were supported
the spyware was bypassed
4 it has no noticable side effects
After installing AutoGK, look under Control Panel/Add-Remove Programs, and check for a program called "DAE". Remove it, and reboot. Spyware gone.
What it's meant to do: Apparently it's a pretty evil one, as spywares go... it reports just about everything you do on the Net to a company called ResponseTarget. Get rid of it ASAP.
P.S. check www.responsetarget.com for more details on what it does. -
No reason why you can't install the apps used seperatly if they are all you want.
Possible spyware problem
By Squid_uk in forum ComputerReplies: 34Last Post: 28th May 2011, 00:19 -
What do you do to keep your PC safe from Virus spyware
By spiderman2k1 in forum ComputerReplies: 48Last Post: 6th Nov 2010, 00:44 -
spyware in windows 7...
By deadrats in forum ComputerReplies: 4Last Post: 6th Apr 2010, 14:50 -
really bad spyware infection....
By SE14man in forum Newbie / General discussionsReplies: 29Last Post: 21st Dec 2008, 23:12 -
AutoGK & Super: Spyware Free?
By Tom Saurus in forum ComputerReplies: 3Last Post: 21st Sep 2007, 10:57
