a friend just purchased a dvd burner for his tv and we wanted to record off the satellite to dvd for some shows. it has a 2, 4, and 6hr speed. i record onto vhs on ep all the time and even though its suppose to be lowest quality it always turns out fine. if i record onto the ep speed on the dvd burner will the quality be as good as if i recorded onto new vhs ep speed.. just wondering if anyone knows..
thank you
Quality is in the eye of the beholder, and different makes perform better at longer time settings. You'll just have to try it and see. Personally I don't like to go above 2 hours, but then I haven't tried a JVC.
"Art is making something out of nothing and selling it." - Frank Zappa -
I agree. I got the ILO, applied the hacks, which got me the 3 hr. mode, and I wouldn't go further than 2 hr mode, unless I don't care all that much about the quality. Oh, and I, too, have a satellite system, that I am recording off of.
2 hours here too, never gone over on any I've owned. Discs are far too cheap to sacrifice all that quality.
I've transferred a lot of movies from my DishNetwork DVR to DVD in the 4 hr mode and they look fine. I've also given a lot to my brother and he says they're fine as well. You could get an RW disk and experiment with different speeds to see which looks best to you....
thanks guys lots of help
thanks johnny c for the info cause i plan on recording a show from 7-11 sunday night and just wondered if it needed to ep or what.. i will record on the 4 hr speed instead of the 6 hr just to be on the safe side..
thanks for the infoif you're not cheating, you're not trying -
Any time! I've found that anything past about 4 1/2 hours or so tends to lose quality fairly rapidly, but up to that looks fine....
You can generally go up to 3-4 hours, depending on the quality of the recorder. Some recorders look bad past 2 hours, inferior chips.
The specs of 4-hour are essentially the same as 2-hour (half res, half bitrate).
The 1-hour 3-hour is a superbit-like bitrates (3-hour res/bitrate at half of 1-hour).
Beyond four hours, you deinterlace your video, which looks like crap.Want my help? Ask here! (not via PM!)
Recording HDTV & Satellite with PC?
By neworldman in forum DVB / IPTVReplies: 14Last Post: 4th Dec 2011, 18:16 -
Satellite TV on P.C software
By gomer in forum DVB / IPTVReplies: 3Last Post: 17th Jun 2009, 08:20 -
How to record satellite program on dvd recorder? Thru scart cabel or RGB?
By szalaikornel in forum DVD & Blu-ray RecordersReplies: 0Last Post: 22nd Jan 2009, 16:05 -
Old Satellite system
By MadDog_Smith in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jul 2008, 15:51 -
sony DVD Recorder and Satellite Tuner Configuration
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 1Last Post: 1st Oct 2007, 14:05
