Results 1 to 11 of 11
  1. Hello my first post here and cant really find a forum with the answers im looking for?All i want to do is copy a label on vhs tape thats (not copyright protected)I have a good scanner.Where do i go from here?I can scan it and save the image as a jpeg etc.What type of softwre if any is designed for this type of thing?
    please help
    allsmiles
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
  3. thanks so much!
    GREAT FORUM
  4. Just print it. What else do you want to do to it?
    This plan is so bad, it must be one of ours.
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    yea - i dont get it ..
    scan it or copy it and print it ...
    i thought you were joking
  6. If you want a label Template let me know.I also thought he was joking.
  7. Sorry not joking,i have never tried to get an image into any software to print on a vhs label.....i dont even know where to get software made just for the vhs labels?
    Im smart with a lot of things just not when itcomes to scanning and printing?Not sure even where to start with my printer?
    Epson r200?
    thanks for any help!
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    you should be able to use word or even ms paint ..with word - there are templates you can use ...
    avery has both templates and lables .. you can buy often both together
  9. thanks for the help!
    You got me started!
  10. Member vhelp's Avatar
    Mar 2001
    New York
    I'm not sure what you're asking here, but..
    You could try scaning it too.
    -vhelp 3258
  11. Guest
    Guest
    www.cdcovers.cc
    They have forums there that may be of help. What the hell is VHS?Is that like a 78?
