Hi,
I am burning a DVD using Nero - burn DVD files. All is fine but when I check out the DVD in the drive using my computer it only displays about the first 10 characters of the disk label I actually enetered. i.e it truncates what I enetered.
What setting do I need to change so that the whole title appears.
I think it's a limitation of the ISO file system. Might be cured by enabling Joliet, if you've not already done so. (Or does that only apply to long file names?)
/Mats -
Come on - someone out there must know !!
I am sure I have burned using copy2dvd and it has put a label far longer than that so there must be a way for Nero . -
I believe that this limitation was introduced in Nero 6 and above. Before Nero 6 you could use longer file names to label the DVD. The last I heard was that someone from Nero would into it as it appears to be a bug in the code.
Mark -
A bug? In Nero? Naa...Originally Posted by mwkurt
/Mats
CD/DVD has ripped label, how do I fix it?
By videohalp in forum Newbie / General discussionsReplies: 6Last Post: 12th Apr 2009, 07:20 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 14:25 -
Disc name/label being cut short in Nero.
By richard_m_morales in forum Authoring (DVD)Replies: 5Last Post: 25th Sep 2008, 13:20 -
DVD Label Printing Advice Needed
By jday in forum Authoring (VCD/SVCD)Replies: 3Last Post: 14th May 2008, 20:35 -
Printed DVD label color washin out
By anubis13 in forum MediaReplies: 19Last Post: 15th Oct 2007, 11:55
