Let's say you created an AVI file and the Audio and Video are out of sync.
Open the file in MediaPlayerClassic
Look for parts in the file where you see closeups of people talking, or some area where you can obviously tell the sync is off.
From the MediaPlayerClassic menu:
View--->Options--->Filters--->Audio Switcher--->Audio Time Shift(ms)
Check the box, and enter 1000 in the number field. Press "Apply" button.
See if the sync gets better or worse. If worse, enter -1000 and see if it gets better. The cool part is that you can continue playing the file as you try to find the proper timings - just hit "Apply" to see the effect in real time.
To fine tune, increase or decrease by 200ms amounts, then 100ms once you're really close. Adjust accordingly. You'll find it, sooner than later.
This won't work in every case, like in a file where the audio slowly begins to drift and is way off sync by the end. Oh, and remember to uncheck the audio time shift box when you're done, otherwise the next thing you play in MPC will be off sync thanks to the player.
Results 1 to 1 of 1
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 17:27 -
Sony DCR-TRV9 mini DV cam, lots of dropouts, lose sync in iMovie
By lipwak in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 28th Oct 2010, 11:20 -
.VOB parts w/ different sync offsets?!
By Gew in forum DVD RippingReplies: 3Last Post: 5th Apr 2009, 00:42 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18 -
Can't figure out usually easy things on the Toshiba RD-XS35
By KeepItSimple in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Jan 2008, 09:54
