Im trying to convert .mov files to .mp4 (you can guess why), but the files arent allowing it. In Quicktime Pro, I get the following message:
"Couldn't export the movie '...' because this movie does not allow saving"
Ive used Rad tools and was successful in converting the file to .avi, with no sound, but when I try to convert that .avi file to .mp4, I get the same message that I did with Quicktime Pro.
To convert files to .mp4, Im using a PSP specific program that converts most all files to .mp4 with various, pre-set dimensions. Its called PSP Video9. I think the only 2 formats it has problems converting are certain .mov and .wma files.
-What can I do to unlock this video?
-Is there a program that can convert .mov to .mp4 directly?
If anyone wants to take their own stab at this, 1 of the 5 .mov files Im trying to convert is the Star Wars Clone Wars Episode 21.mov, downloaded off of Starwars.com directly (should be legal).
Heres the link - Its about 50mb
Sar Wars Clone Wars Episode 21
When I was born I was so shocked that I could'nt speak for 18 months.
Doesnt work.
Its doesnt tell me much, other than just 'Fail'
Anyone else have any ideas? -
Its honestly that these files are" locked" somehow. And no ammount of converting is unlocking them.
I was only able to convert these files to .avi with a program called 'Something Something Cleaner' (forgot the name). But it added a permanent watermark, distorted the picture dimensions, and was still "locked" from being converted into anything else.
Bummer... -
I downloaded the file (animation) from the link you gave above and was able to convert about 5-6 min of it to mpeg-2 with TMPGEnc. You have to make sure that the quick time filter priority is set to the highest.
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
Mov conversion help?
By Timbo78 in forum Video ConversionReplies: 2Last Post: 13th Sep 2010, 06:10 -
MOV file conversion
By pidasms in forum Video ConversionReplies: 6Last Post: 13th Dec 2009, 15:42 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
flv > mov conversion fails, empty file, why?
By sduck409 in forum ffmpegX general discussionReplies: 2Last Post: 5th Feb 2008, 22:04
