A friend brought me a home movie in kvcd format. I wanted to put it on a dvd for him, but when i try to add it, the tmpgenc dvd author tells me that the GOP i too long. How can i change that?
I tried converting it, but then i only get half of the movie. The run time is listed at 38 minutes.
anybody help?
You can use DVDPatcher to patch the file in order TDA to accept it. Do not forget to patch it back after that. Alternatively you can use another authoring programm, but pay attention to the audio sample rate - for DVD should be 48 KHz (TDA will resample automaticaly).
Either way there are good chances it will not play properly.
About the duration - did you test multiplexed or elementary video? -
When tda says the gop is too long just choose ignore,if it also says the resolution is wrong(480x480)then use dvdpatcher as mentioned by Abond.
Running the video thru tmpgenc\mpeg tools\merge and cut fixes problems when only half the movie shows up when authoring.I think,therefore i am a hamster.
KvCD to vob
By natty in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2010, 15:37 -
MPG to KVCD HELP
By G33333 in forum Video ConversionReplies: 12Last Post: 25th Dec 2007, 06:00 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 15:31 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 11:08 -
KVCD to DVD
By buttzilla in forum Video ConversionReplies: 2Last Post: 6th May 2007, 08:01
