  1. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    eh, im not a network guy. what can i say. but i need to set a proxy for my computer. i know how to do it with IE and FF but i need it so everything that connects from my computer runs off of the proxy. im thinkin i can do it with my firewall but im not at home to look at it. if not what other options do i have? thanks.
  2. Member Abbadon's Avatar
    Dec 2003
    Caribbean Sea
    Hi,
    Setting up a proxy server normally requires a dedicated computer, I personally prefer a NAT server (Network address translation) which it is a both a firewall and a router. The use of a proxy is currently to achieve goals such as:
    1) Provide Internet connectivity to several hosts when there is only one internet connection.
    2) Anonymous web page surfing.
    3) Bandwidth use monitoring per user.
    4) Acceleration of web pages loading.
    5) Access Control.
    You would need a Linux box with a properly configured package called Squid and all the security measures available or a Windows box with the Proxy server, but this last option is not free.
    You may find good information here about Linux here:
    http://www.linuxheadquarters.com/howto/networking/squid.shtml
    http://www.grennan.com/Firewall-HOWTO.html
    No tengo miedo a la muerte. Solo significa soñar en silencio. Un sueño que perdura por siempre. ..
  3. Member Soopafresh's Avatar
    Jan 2004
    If you want EVERYTHING to go through the proxy, you'll have to go through a SOCKS 5 proxy server. There are commercial subscription Socks proxy servers you can go through, or less reliable public ones, which get shut down fairly frequently.
    You have to load an app on your workstation to act as the middleware between your app(s) and the socks proxy.
    http://www.socks.permeo.com/AboutSOCKS/SOCKSOverview.asp
    BTW, you don't have to do this if you just want Http and FTP proxying. You can use a standard proxy server (non socks) to do this.
  4. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    so call me retarded...what do games go through? what type of connection
  5. Member studtrooper's Avatar
    May 2004
    The Beyond Section
    Why would you want to game through a proxy? You banned from something and want back in?
    Your base? Well, they belong to me now...
  6. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    no not banned from anything. just tryin to temp relocate myself
  7. Member Soopafresh's Avatar
    Jan 2004
    Games would go through a Socks5 server typically, but here's an app that allows you to go through either. Your proxy server is going to have to be a fast one, located elsewhere, optimally in another country if you want to mask your IP address.
    http://www.totalrc.net/s2h/index.jsp
    PC--->FirewallRouter--->Cable/DSL Modem--->InternetRoutersX5--->Proxy
  8. Member studtrooper's Avatar
    May 2004
    The Beyond Section
    Yeah, that might equate in to one hell of a ping depending on who you choose... might not be worth it if it brings you down to a 56k'ers level.
