  1. I have recently downloaded a collection of music videos that are in DTS format. What do I do with them? How do I view them? Can I burn them on to a DVD? How?
    I tried playing them in the new version of PowerDVD. The onlyout put I get is a very faint audio stream and only some type of visualization for video output.
    I tried various codec packs but to no avail.
    Anyone have any ideas?
    Rick
  2. What do you have a vob file or just a .dts file?
    You can always make a DVD with ity in DVD Lab Pro
    DVD Questions?
    dvdquestions.com.au
  3. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    If they are VOB files you can burn your DVD with your favorite application. It's going to be a Music DVD. Still, if they're VOB files you can use BeSweet to go from VOB to WAV.
  4. Unfortunately, theres no VOB just .dts. I've burned those types of files before.
    I've only tried NERO to burn the files on a DVD-RW and CD-RW and neither of them played.
    Thanks for the replies.
    Rick
  5. dts files are audio only - Digital theater sound (AFAIK). You can make them wav files with BeSweet+BeSweetGUI and burn as audio CD (well I think )
  6. I thought DTS files were audio as well, but they came from a burnt DVD of music videos.
    Rick
  7. If all you have is dts files there is no video. What do you want to do again? Just preview the files on your computer ?
    DVD Questions?
    dvdquestions.com.au
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    if powerdvd doesnt play them - try windvd ..
    but powerdvd should play them -- sounds like they are screwed up or are they off a cinema cd ?
