I have a home wireless network Using a linksys WRT54G router and a WUSB54G adapter. I had winxp sp1 on the computer connected with the adapter and it was running great. I updatedto SP2 and now the adapter can see my network or connect the internet anymore.....Need help, I'm all out of ideas...... The router is working fine because this computer is running on it as I type....
Results 1 to 9 of 9
What We Do In Life, Echoes In Eternity....
Have you tried disabling and re-enabling the network connection.
yea didn't help...I just did some reading on other forums and stuff and it seems that a lot of people are having tha same problem with this adapter. Not everyone with the adapter but I've already counted 120 people that it won't work. Also looks like Linksys knows about the problem and can't fix it, so it is just ignoring it now......
What We Do In Life, Echoes In Eternity.... -
Have you tested the new drivers that Linksys released last week?.
http://www.linksys.com/download/driver.asp?dlid=143
This version passed Windows 2000 and XP WHQL. -
I have Wusb54g version 1 can I update it to the 4th version?
I just used this site to update.
http://www.linksys.com/download/driver.asp?dlid=143What We Do In Life, Echoes In Eternity.... -
I don’t think changing drivers will work because version 1 is based on PRISM chipset and Version 4 uses Ralink chipset.
My USB adapter is version 2.
If your router is a WRT54G you could also try upgrading its firmware to 3.03.6. Get the file in here: http://www.linksys.com/download/firmware.asp?fwid=201
After installation of any wireless product, by default, Windows XP launches its own internal configuration utility (Windows XP Wireless Zero Configuration Service). Since I had several problem with the Windows own wireless configuration manager, you may try using Linsys Wireless network monitor.
From the systems tray in the lower right corner of your screen, double-click the Wireless Network Connection icon. The Windows XP Wireless Network Connection Screen will appear.
Click Properties. The Windows XP Wireless Network Connections Properties screen will appear.
Make sure that “Use windows to configure my wireless network settings” check box is not selected.
Click OK and close the Windows XP Wireless Zero Configuration Service screen.
Finally configure the USB card using the Linksys wireless network monitor that came with the latest drivers.
Hoppe this helps. -
To Denver Dawgs,
There is a new driver for the Linksys USB Network adapter. Take a look at this: https://www.videohelp.com/forum/viewtopic.php?p=1324406 -
oh sorry, for not updating. I'm all set now. Thanks for your help
Wireless Network for Multimedia
By DarrellS in forum Media Center PC / MediaCentersReplies: 0Last Post: 19th Feb 2011, 01:22 -
How Can I Set-Up the Linksys Wireless Router??
By Frank-0-Video in forum ComputerReplies: 9Last Post: 27th Feb 2009, 16:18 -
2Questions... boot ini and ethernet network. xp +sp2
By surfmonkee in forum ComputerReplies: 4Last Post: 14th Nov 2007, 11:34 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 3rd Nov 2007, 00:56 -
xbox-1 wireless network?
By stackner in forum ComputerReplies: 1Last Post: 21st Jul 2007, 05:25
