Erasing on LiteOn 5005 is driving me nuts. Everytime I try to erase one icon (title) of say four I've taped, all the icons (titles) are erased. This can't be right. Can't find solution in manuel. Am about to take it back to the store. Help![]()
As far as I know, that's how it works -- when you erase, you are erasing the entire disc. I have the same model, and that's how it works on mine too...
George -
are you highlighting the title, then pressing the edit button, then select erase? The only way I could see you erasing the entire disc is if you erased in the easy guider menu
Thanks solidsnake. It works. Couldn't find that in manual. Still not sure if I'm going to keep it. The playback seems fuzzy, even at different speeds.
those units have crappy playback, I'd suggest playing it on a better dvd player hooked up with component if you got it, then decide. I never watch what I record on the recorder itself, it puts a green tint output that you dont see when you watch it on a different player.
What I've Learned so Far-LiteOn 5005
By RiteOn in forum DVD & Blu-ray RecordersReplies: 27Last Post: 14th Oct 2012, 20:58 -
Liteon 5005 dvd drive
By kenmo in forum DVD & Blu-ray RecordersReplies: 8Last Post: 15th Jun 2010, 14:58 -
Liteon LVW-5005 can’t prepare 16 X DVD-R before recording
By coody in forum DVD & Blu-ray RecordersReplies: 24Last Post: 8th Jun 2009, 14:54 -
LiteOn LVW-5005 timer recording fails?
By bevills1 in forum DVD & Blu-ray RecordersReplies: 15Last Post: 13th Jun 2008, 09:37 -
LiteON 5005 weirdness
By kenmo in forum DVD & Blu-ray RecordersReplies: 53Last Post: 2nd Jun 2008, 11:05
