Hi guys.I have a problem with recording my DVDs.I'm using Nero Vision Express to burn the movies.It used to work perfectly.The movies which were in XVID file format after encoding in Nero Express were burned onto the cd.The process usually took about 4 to 6 hours depending on the length of the movie.The first step was creating menus etc and it used to take from 5 to 10 secs.And now is taking an hour.And all of a sudden all movies I try to burn stop almost at the same time of burning. Then I get a memory problem window pop out and then the program crashes.I have no idea what could that be.I tried diffrent movies and several versions of Nero Express but the program persisted.I don't know any other softwares that would work as simple as nero express because when I tried Nero burning room the file format wasn't good same thing with Cd Creator.Nero express is the only ware I know that would burn right away the film.Please help me out guys.Thanks in advance
Results 1 to 1 of 1
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 06:16 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Memory Problem
By SIRCOOKS in forum ComputerReplies: 2Last Post: 7th Feb 2009, 09:55 -
a weird memory problem
By ahhaa in forum ComputerReplies: 3Last Post: 6th Nov 2008, 11:15 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 07:19
