my brother has just got an iriver h320 and he said that the video playback requires the video to be:
File format: AVI
Codec: XviD MPEG4 (recommend XviD 1.0.2 codec)
Resolution: 220 x 176 only
Frame Rate: 10fps at Maximum
Bit Rate: 500Kbps at Maximum(recommend under 450Kbps)
is there a program out there that will convert almost every video file type, vob, mpeg, avi etc to this required spec?
You will most likely end up with several programs. Take a look in the "How To" section under "convert"
Google is your Friend
Xvid on Iriver X20 - Flickering
By kidcash in forum Portable VideoReplies: 2Last Post: 8th Jan 2008, 04:43 -
Which software to convert video for iriver Clix2?
By ShaqArif in forum LinuxReplies: 1Last Post: 20th Aug 2007, 14:53 -
sorry for the offtopic! need an advise on iRiver iHP-100-THE HD IS DEAD!!!
By lubegiant in forum AudioReplies: 1Last Post: 1st Aug 2007, 11:12 -
iRiver H120 - Does it REALLY support WMA, if so how do I update the DB?
By amdk62 in forum Newbie / General discussionsReplies: 1Last Post: 11th Jul 2007, 17:56 -
Any IRiver PMC 120 Hack ?
By StoneColdWhat in forum Portable VideoReplies: 0Last Post: 20th Jun 2007, 15:53
