The DVD Quality settings to enable deep analysis, etc., do not work. I am not able to select them. They are grayed out. How can I select these settings, Ver. 3.2.0.15?
They will be greyed out when there is no need of compression. That is when the DVD you are trying to shrink is single layer.
If your movie will fit on a single layer disk with out compression, then there is no reason those settings and DVD Shrink will not allow you to select them.
Nyah Levi -
Thanks guys. I figured that out when I noticed automatic(100%) and then put in a big movie with 55%. Now, the options are available.
Thanks again for your quick reply.
Best h.264 setting for optimal size/quality with handbrake.
By frickfrock99 in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2010, 03:09 -
Resampling quality setting in Ulead VideoStudio
By eclipse95 in forum Video ConversionReplies: 20Last Post: 16th Sep 2009, 21:08 -
DVD Shrink setting
By jyeh74 in forum Newbie / General discussionsReplies: 18Last Post: 8th Apr 2009, 10:45 -
Help setting quality settings on mencoder converting videos on my website!
By funnyspo in forum Newbie / General discussionsReplies: 0Last Post: 12th Feb 2009, 17:55 -
DVD shrink vs DVIX video quality
By sportflyer in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2008, 21:31
