Hi Chris hows the work going on RC8 and any idea how long before final will be out
Results 1 to 15 of 15
RC8 is basically ready to rock. FINAL will be out once the remaining bugs are quashed.
? did you fix the buffer underflow
problem
im willing to test it if you did
thanks yours clive -
You know what would be awesome? Custom scene marking. The auto scene marking is already great but is it hard to put in a simple tool to mark your own scenes? Like you go with a slider bar where you want it, press a button and BAM a scene is marked? That would be so awesome. If you put that in i'll donate another 10 bucks into your accont.
Nearly there. I will get you a test release tomorrow, hopefully.Originally Posted by britincanadaSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I agree this would be good. Might not make it for 2.0 but maybe 2.1!Originally Posted by dickkwikkwekSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I NEED HELP[!!! I JUST PURCHASED SVCD2DVD
I TRYING TO OPEN THE BIN FILES FROM THE VCD
BUT I CANT SEEM TO FIND THEM
THEY ONLY FILES I HAVE ARE CDDA, CDI, EXT, KARAOKE, MPEGAV, SEGMENTAND VCD.
ALSO THE VCD IS FROM HONG KONG AND PLAYS ON REG 1 DVD PLAYERS
DOES ANY ONE HAVE INFO ON THIS? -
The dat file in the mpegav folder is the file you want. Copy it to your HD & rename it to a *.mpg. Then process as normal.
hey ChrissyBoy,
would be possible to make a translation tool for another languages?
i would be pleased much about it and would be ready to make a complete german translation for your great application
thx for hearing -
I will look into the mechanism for this. Thanks for the offer.
ChrissyBoy, can you give a basic idea about how long it takes till 2.1? Or whatever the version is that will have the scene feature i mentioned?
I'm sorry but i can't. It won't be for a while if my PC keeps dying on me...Originally Posted by dickkwikkwek
