There has been a short discussion in another thread about what method should be used when lifting frame samples for comparison, and it turns out VirtualDubMod does a much better job of that than PowerDVD does.
Apparently, PowerDVD has some issue with the Panasonic 704x480 recorded MPEG2 format that causes the frame grabs to look softer and less defined than they really are. I quickly checked out my E55 and E50 recordings using VirtualDubMod to do the frame grabs, and they looked pretty good (the black levels were basically the same, but the sharpness and detail were much better than with the PowerDVD frame grabs).
So, I will be re-posting some of the various test recordings I have made using VirtualDubMod as the frame grab tool... and now we have an explanation as to why the Panasonic test frames I posted before looked a little soft and fuzzy, and why so many have been puzzled by this result (since they are certain their Panny recordings are sharp and clear).
Sorry for the confusion - but we learn as we go.
Edit -
OK - even more frustrating is the DVD-RAM I used to record E55 and E50 test images now is suddenly unreadable! I don't have the units on hand anymore, either. Oh, well! If I get a chance to get another Panasonic, I'll re-do the tests and compare results.
Results 1 to 1 of 1
picture control on Panasonic dmr e55
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jan 2012, 16:41 -
How to set correc IR (black level in panasonic dmr e55 and es15)
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 13th Nov 2011, 09:42 -
Sony/Panasonic m2ts file date correction
By renzo2000 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Aug 2010, 16:07 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 13:09 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 17:15
