Can anyone help with a firmware upgrade? I purchased a LaCie
Dual Layer 16X recorder, which is actually a NEC ND-3520A with
formware 1.04
I cant get the drive to burn at more than 4X, and cant find any
newer firmware, even though some units have shipped with 1.06,
and I have read of folks using an official NEC firmware of 1.07
Nothing on the NEC site.
thanks,
Win
Results 1 to 11 of 11
thanks, but i checked that site previously. They only
list version 1.04
Win -
winman42
Check this web site
The Dangerous Brothers
http://tdb.rpc1.org/
I have a 3500 and it burns up to 16x with good media.
What media are you using?? Also make sure you have DMA turned on -
list version 1.04 -
OK, Trock....on the first site link i dont see the LaCie drive listed, I only see the following: Nec, Maddog, I.O. Data, and Memorex. Looks like the 1.26 you mention is for the I.O. Data unit.
Media wise, i've tried TDK, Fujifilm, and Ritek. All are
maxing out at 4X with Dvd Decrypter.
Win -
thanks for the help guys....i guess i should have said
that i'm looking for an OFFICIAL firmware, before i
start trying hacked versions.
Win -
Make sure you are not using TDK 8x -R media. NEC "officially" rates these at 4x and they should. Trying to burn this media at higher speeds on some burners produced coasters.
Buy a Verbatim 8x +R and -R media. Try these. If they burn at the rated speed then you should not pursue the f/w issue further.
The DMA setting is rather difficult to slow burning speed to 4x. If your RW driver was on PIO mode it would top off at 2x, so the most suspect thing is the media.
Also, can you provide info on what burning s/w you are using? If Nero, are you using at least 6.6.0.3 or higher?The more I learn, the more I come to realize how little it is I know. -
1.04 is the latest official ND-3520A firmware. Mine burns Ritek G05 at 8x, CMC MAG AE1 at 8x and Verbatim Pastel (TYG02) at 12x even though they are only supposed to be 8x media.
Richard, thanks for the info. I was told by others,
on a different forum that 1.07 was the latest 'official'
firmware, hence my search. Obviously i was misinformed,
and will check out the media you speak of.
Win
GoVideo DVR4100 Firmware Upgrade
By csupan in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2009, 21:03 -
Samsung BD-P1500 firmware upgrade
By D-Generate in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Mar 2009, 06:50 -
DVDR-3380 Firmware upgrade
By Spideray in forum DVD RippingReplies: 2Last Post: 25th Jan 2009, 02:13 -
Would you still buy an NEC ND-3520A today?
By Number Six in forum DVD & Blu-ray WritersReplies: 13Last Post: 20th Mar 2008, 08:24 -
NEC ND-3520A writes DVD's, which it cannot read
By Ruut in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 12:36
