  1. Member daamon's Avatar
    Melbourne, Oz
    Hi All,
    I've just authored a DVD of a friends wedding and have realised that one of the chapters would be better off starting earlier than it currently does. Now, I could change the start time in TDA (which I used originally) and then re-author, but I can't help thinking that either ifoedit or PGCedit will do the job.
    I've had a look at both tools to see if it's obvious. It wasn't.
    I've done a search but couldn't find anything that helps.
    I've looked at 2COOL's guides over at doom9 (there's loads!!!) but not one that appears to cover what I want / need to do.
    Does anyone have the answer / any ideas?
    Thanks.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  2. Member daamon's Avatar
    Melbourne, Oz
    Anyone?
    Carpe diem.
