  1. I ripped a DVD using SmartRipper. Used DVD2SVCD and then ripped the audio with Vob2audio. Using TMPGE set with the Video-CD NTSC template I converted half of the DVD and burned it with NERO and it came out great. When I try and convert the second half(starting at the frame where I left off using the Source Range and ending frame at the end of the DVD)there is video but no sound. Everything is exactly the same as the first conversion except the starting and ending frame. What I'm I doing wrong with the audio on the second conversion attempt??
  2. Found the problem. Vob2audio was only ripping half the audio. I uninstalled and reinstalled it and it works fine now.
