I'm a bit confused, I like authoring all my movies WITH menus unlike alot of folks. When I go to the create menu tab in TMPG Author,... there are no options... everything is blank. There are drop down tabs, but they are all empty.
Am I suppose to have something there or what??
Closed Thread
Results 1 to 9 of 9
TDA can certainly generate menus - based on a number of different templates.
Check out one of the guides that covers menus with TDA (there's bound to be one) - it might point out something you're missing.
Or your installation of TDA is knackered.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Hi Chaze,
It's as simple as Install TDA -> Load MPEGs / VOBs as your source files -> Create Menu from templates (in drop-down boxes) -> Create output.
I'm not at my PC at home, so can't access TDA. But it's pretty intuitive and nothing additional needs to be loaded. The templates are there from scratch.
This guide ( www.videohelp.com/forum/userguides/198813.php ) at about 80% of the way down the page, has a screen shot of the "Create Menu" step. To the far left, there is a drop down showing "Cloud 1". This drop down accesses the templates.
Play with "Edit Menu Theme" and "Display Menu Settings" to figure out what they do...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Let me make myself clear,...I know how to go into create menu/ edit menu theme, etc,... but in the drop down tabs,... the fields are all blank. It looks like something is suppose to be there, but it's not.Originally Posted by daamon
The layout tab, button tab, etc,...the fields are all blank.
contact where you bought the program from and get another copy - make sure you entered your serial number correctly ...
burning a dvd from a 'friend' is considered warez also ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 11:00 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 14:16 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 04:53
