Ok, my multisystem VCR has been working in LP mode only for a while, while I also have another spare PAL or NTSC VCR (with PAL output only or NTSC 4.3)
I connect the two with SCART cable with Multisystem one being last in the chain.
Here's the deal.
From one of my VHS tapes I was able to extract this image as comparison between the two VCR.
If you compare the frames the Samsung (multsistyem one) has much more vibrant picture color quality while the other one, although it is higher in contrast, makes my eyes hurt.
(it looks like there is a green-see-through-curtain accross the entire screen)
Considering we have all these tools availalbe would it be worth it to adjust colors and how in other words I could emulate the picture quality of SAMSUNG VCR?
(also for example in Tmpgenc there is a Custom Color Correction box that I have tried using many times but when I would adjust one segment the next one would get screwed up - is there a specific colorspace that I should use YUV, RGB, Etc etc).
Picture one (damaged VCR - which I preffer better).
Picture two (healthy VCR - the one I don't like)
thx
Look at the letter L on the lower left. You will notice that in my preffered VCR is just simply more yellow than in the other one.
thx again.
Results 1 to 1 of 1
Adjusting the INPUT video???
By pooksahib in forum Video ConversionReplies: 4Last Post: 10th Jan 2011, 00:55 -
Adjusting vobsubs for new AR?
By Xavier in forum SubtitleReplies: 1Last Post: 4th Mar 2009, 11:41 -
Adjusting amount of light
By ProducerHarley in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 28th Jan 2009, 18:07 -
Adjusting Playback speed?
By Scav2003 in forum MacReplies: 3Last Post: 27th Feb 2008, 11:57 -
filtering scratches/bands
By AlanHK in forum RestorationReplies: 0Last Post: 4th Oct 2007, 06:00
