I have the TV2000XP Expert and have everything working pretty well except the TV tuner. For some reason it just does not want to work with my cable hookup and sure could use some help getting it to work.
My home is wired for cable to most every room in the house. The "wiring" includes several splitters to accomodate all the cables and all of my TV's work fine with the cable.
I had an extra cable laying around and decided to disconnect the cable from a room that does not have a tv in it (strange as that may sound these days) and connected the spare cable to the splitter and then to the cap card. I did the required channel scan and other than a couple of very snowy channels, this card is not picking anything up from the cable.
I updated the drivers and application software from Leadtek's website and that didn't help. I bought a new cable and installed it. That didn't help. I finally connected a VCR in-line between the main cable splitter and the back of the cap card and I get really great reception as long as the VCR is turned on and use it as a tuner. Unfortunately, it is a pretty old model and I am limited to about 17 channels.
I have emailed Leadtek support and haven't heard a thing from them so I am hoping someone here might a solution to getting this thing to work right.
Any help will be greatly appreciated.
Thanks,
Vance
What capture program are you using?
Did you specify CABLE as the tuner input, and not ANTENNA?
Did you do a channel scan using "all frequencies" or standard North American frequencies?Cheers, Jim
My DVDLab Guides -
I am using the bundled software that came with it - WinFast PVR(?). I did specify cable and not antenna. I did a "Scan Channels" and "Auto Fine Tune" for USA.
You've done a lot of troubleshooting yourself.
Other than trying a different splitter, I tend to think the tuner has crapped out.
Can you test the card in a different computer?Cheers, Jim
My DVDLab Guides -
sounds like my setup... my cable is split three times before it reaches my computer
I don't know what to say, mine works like a charm... call over a friend to look at it?
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 12:32 -
Does the SpursEngine devices, IE Leadtek's WinFast PxVC1100 work good?
By TBoneit in forum Video ConversionReplies: 3Last Post: 15th Aug 2009, 17:50 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 10:05 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
