  1. hi all
    ive d/l a divx movie which disk 1 is 688megs(its a divx not mpeg) anyway i converted it to a mpeg using TMPGENC all went well except it took bloody 5 hours to convert and now im left with a MPEG which is 1.69gigs...
    and thats only cd1 now the same will happen when i convert disc 2 but howe on earth do i burn 3.5gigs on 2 cds...(2 cds is what i normally use when ive converted a divx into a mpeg
    please help as i want to watch this good movie
    thx
    Niftynew
    are you making vcd,svcd or dvd? if you make vcd be sure to load the vcd template.
  3. yes im making a VCD not svcd
    and ive loaded in the correct template (VIDEO CD (PAL).MCF)
    also tried the NTSC 1 but its just the same??
    i think now i got to think about COMPRESSING? the divx so it smaller....is this it????? that way i can convert the smaller divx into a mpeg for VCD
    the total amount of megs for the WHOLE movie is 1,377 (never seen a divx this big before??)
    thx for replying
    regards
    Nifty
  4. I'll say this again, how long is the movie ??? it doesn't matter for VCD what the mb's are, one 80min CD will hold 80min's of movie (at VCD spec settings). Thus if your movie is 3 hours long it will take 2 and a bit CD's...
  5. ok the movie is 128minuites long BUT its in DIVX format and the total amount of megs for the movie in divx is 1.34gigs
    the divx is in 2 sections 1 = 688megs 2=689megs now when i convert the number 1 into a vcd using the VIDEO CD .MCF settings it converts BUT it converts to 1.69gigs now when i load this in nero it goes way past the 90minuites mark...i cant see further?
    u say "it doesn't matter for VCD what the mb's are, one 80min CD will hold 80min's of movie (at VCD spec settings). "
    BUT what do u mean by VCD SETTINGS??? ive allways done my converting like this and never came across a DIVX file at 1.34gigs,,,i know this must be something to do with the person that has ripped it but is there a way i can SHRINK the divx file ive got? that way i can convert the smaller divx file into a MPEG for vcd
    thx for replying again
    regards
    Nifty
  6. I am sure you've done something wrong, as a VCD size will always be the same for the same minutes if u use the same settings!!!! And you can's 'shrink' it, there would not be any point even if you could! Maybe you did not compress the audio to mp2, but only to wav from mp3? Or I don't know... but if the movie doesn't last longer than 148 mins than you will be able to put it on 2 cds.
    Jroy
  7. with the sound first time i did it i choose full processing mode and now with my m8 on the fone i got him to choose the other setting in virtual dub and now the audio ive ripped is only 70megs instead of the first time i choose was nearly 1 gig...i think that was my problem...if i get in any other probs ill let you all know
    BUT thx for all the help u gave i really appriciate it
    cheers agaian
    Nifty
