I read through some topics like this, saying check if DMA is on, and it is, but it's still not going any quicker.
With some discs it'll only burn at 1x no matter what, and with other it'll burn at 2x, even if the disc are 8x ones then selves, and even if i tell the computer to burn at 4x. The writer is an 8x one, DVD Dual is the make.
Can someone please help as it's taking an hour to burn a DVD.
Results 1 to 15 of 15
well it 3.0ghz, 1gig ram, 160 hard drive. Its still rather new, about 7-8 months, so i don't think it'll be the computer.
try firmware updates as a 8x is a little old now (@12 month+)and it should be some out there,burn at 8x all the time now adays has the media is mainly 8x now, very little below that round me
any idea who makes the drive (DVD Dual)
is it one from asda ,walmart ; name ring a bell on a standalone dvd play at one of these stores (now its a dvd-+rw put can not find a site for it )
has it got a FCC code on it has that might help in find the maker or CE code in uk or both -
No clue who makes the DVD Dual burners, thats really all it says on it.
Also i'm not very good with all the computer stuff, so i don't really know what a fireware update is, is there a link to infomation about it anywhere?
Also thanks for the help. -
Go to Device Manager->DVD/CD-ROM drives.Originally Posted by Vex
Go here for firmware: www.rpc1.org
I would go to the BIOS(hold the "delete" or "F12" button when booting) and check to see that your drives are set to Auto for PIO and UDMA.
BTW...what media are you using and is this a new problem? -
Just cause DMA is ON doesn't mean its using it. Go look under the DMA box & see what DMA mode its using.
Cheers for all the help, i've got it working now and burning quicker than ever, so thanks to you all.
ok, well i went to www.drvupdate.com and download the main program in there, and then updated the fireware, and now its burning like a charm.
I have a similar problem. No matter what DVD Burner only burned at 1x even when I set DVD Decrypter to burn at MAX or at 4x. The DVD-R I have can do it up to 4x.
I checked the properties of the D drive and it shows:
current reading speed 1x
current writing speed 1x
Is there anyway to change this to a higher speed? Sorry, I'm a computer dummie....so if there is a way please show me how.
Or is it because my DVD Burner is limited to burn only at 1x and there is no way to get around this?? -
@yenly,
You might want to fill out your computer specs.
Have you tried Nero DriveSpeed? -
I forgot to add that it's an internal ATAPI (IDE) interface drive that came with my desktop when I bought it from Gateway.
It's Panasonic DVD-RAM LF-D311.
I don't have my computer specs memorized...if you need that I'll get it later this evening when I'm home. But with the DVD burner I listed above, can you tell whether or not it's limited to write only at 1x? Or is it a setting I would be able to change? -
Try doing what i did and download a new fireware go to the link that MOVIEGEEK gave http://www.rpc1.org/
@yenly,
Your Panasonic can only burn DVD-R at 1x:
www.videohelp.com/dvdwriters.php?DVDnameid=16&Search=Search&list=2#comments
Multisession DVD Burner and Burning Files into Specific Folders
By Disco Makberto in forum ComputerReplies: 9Last Post: 23rd Feb 2010, 02:48 -
dvd Burner crapping out while burning DL disc, need help
By mazinz in forum DVD RippingReplies: 7Last Post: 21st Jan 2009, 18:38 -
Trouble burning DVD+R DL with Pioneer burner
By RoyGBiv-inRI in forum DVD RippingReplies: 11Last Post: 17th Oct 2007, 11:43 -
burning dvds without dvd burner??
By lordscrubba in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2007, 10:19 -
DVD-ROM to DVD Burner Direct Burning
By Wilson7777 in forum DVD RippingReplies: 6Last Post: 15th Jun 2007, 12:37
