  1. Does anyone know how can I normalize mp2 files.
    Here is the situation. I have almos 600 mpeg2 musical video clips and they have difference on volume.
    I'm looking for a tool(s) to create a batch to:
    1. Demultiplex the mpeg2
    2. Normalize all mp2 files
    3. Multiplex the files again.
    Please help me on that.
    Thanks.
    Airton
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I think you'd be looking at a few commandline tools, and either a batch file or custom software program/script to control everything for you.
    mpgtx and possibly ffmpeg can handle the demux/remux, the possibly besweet to normailse the audio.
    If in doubt, Google it.
  3. I found a way to do it.
    Thanks a lot.
    i'm using TMPEGenc Editor
    goldwave
    Imtoo Encode
