  1. I've had to renstall a new PC.
    I need to get some codecs installed.
    Can someone tell me where I can get 'safe' codecs?
    I've heard soo much about codecs with malicious software in.
    Thanks.
    Jam
  2. Don't dl any codec paks. Just download one by one as you need them. Get yourself the xvid codec off this site for starters
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    I think a number of codecs without the spyware/adware costs. There are the pro versions of the software.
  4. Exactly why is it NOT recommended to install codec packages?? Is it solely b/c of spy- and adwares?? If so, couldn't you just run spy/adware removal app after installing?
  5. Banned
    May 2003
    Massachusetts
    No, the codec packs don't have spyware.
    However, they were assembled by retarded warez monkeys, so they often set up bad associations and line up the codecs/filters in a lousy order such that it's impossible after a while to get ANYTHING to play back properly.
  6. on this subject, how could i uninstall a particular codec without affecting the others?
    thanks
  7. Member Skith's Avatar
    Bottom of the ocean
    If add/remove programs is not an option, you can open control panel -> Sounds and Audio Devices -> Hardware tab -> select Video Codecs (or Audio Codecs) -> properties button
    That will show you what you have installed. Be careful of what you remove. I would advise removing something only if you know exactly what it is.
    Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
