It is a vr4940 unit will not pull tape in so if you push it in it wont eject any idea's..Sorry if this is the wrong forum
Results 1 to 9 of 9
get new one ..
they are a disposable item and something is bent"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Any VCR I've had long enough eventually had a tape mechanism problem, something has mis-aligned. You can possibly bring it to a TV/VCR repair place (if you can find one these days) but unless the VCR cannot be replaced for some reason it will probably cost you alot more to fix it then the buy a new one...
Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge. -
yeah, I called the local tv repair shop the other day to enquire about vcrs and he said, "vcrs? why do you want vcr? Vcr is dead!" Honest, that's the response I got.
Gonna be like shoe repair before long! -
You should give you model number of VCR for us.
Unplug it, unscrew the top, real easy to do, the tape is probably caught on a roller, you can see that. Undo it & it should come out. Don't use that tape again. Get a new one. -
Contact the repair service or do something better, get yourself a DVD and backup your precious videos on DVDs. I've had a problem like this 2 years ago - my neighbor dropped by to watch his video. He took my VCR to a repair shop around here...That was for about U$ 30.00 but I seldom use that old thing.....
GoVideo = crap, not worth fixing.
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 13:31 -
Sony SLV-700HF VCR Won't eject tape...HELP
By bjo.love in forum Newbie / General discussionsReplies: 4Last Post: 14th Jan 2012, 14:58 -
VHS tape won't rewind in mulitple players
By robjv1 in forum RestorationReplies: 15Last Post: 19th Aug 2009, 18:18 -
DVD tray won't eject...
By zowiemagic in forum DVD & Blu-ray RecordersReplies: 6Last Post: 25th Dec 2007, 16:03 -
Recording a NTSC VHS Tape with a PAL DVD Recorder??
By Lanno in forum DVD & Blu-ray RecordersReplies: 10Last Post: 5th Sep 2007, 04:42
