  1. Hello all,
    Sorry if this is a dup...
    The Incrediles Bonus disc rips fine and burns on to 2 DVD5 fine.
    But when the on screen menu comes up, the "selection box"(used to select what feature you want to see) disappears.
    Now I found out last night that technically it is still there. When I press down or up and hit "ok" a feature will launch, but I have to guess which feature is actually selected. Get Me?
    I used DVD Decrypter 3.5.2 and CloneDVD2 2.6 to split. I had "Preserve Menus" selected.
    Any thoughts or is this as good as I am going to get it?
    Thanks!
    GO SOX AND PATS!!!
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    I haven't mucked around with trying to figure out why, but I get the same results when shrinking to one disc. You have to count your way to each menu ("One down, I'm on this menu, two down, I'm on that menu, etc.") I just re-authored using DVDWS (only keeping the Hero Files menu).
    "Probably some new copy protection."
    MackemX?
  3. Ok, thanks! At least now I know it is not something I am doing. It works fine, just (like you said), you have to count your way through
    Thanks again!
    GO SOX AND PATS!!!
