Hi,
Wehn I try to convert a divx to mpeg with tmpegenc i get a deciaml data error about 13 minutes into the play. Does anyone know how to reapir the divx file, I havre tried divfix, and get a io error.
use vdub and make a direct stream copy, then encode the copy, has fixed about 90% for me.
save yourself another headache and use vdub to strip the audio from the dixv before encoding, then use the wav file for your audio source, otherwise you will almost surely have an audio sync problem.
TMPEGenc h.264 conversion error
By iGnight in forum Software PlayingReplies: 2Last Post: 16th Jan 2011, 11:14 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 21:33 -
Virtualdub error, currupt data?
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2007, 14:08 -
TMPEGENC keeps closing itself because of an error
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2007, 01:38 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 02:23
