it came out as:
C
File : 438 MB (432 MB), duration: 0:43:59, type: MPG, 1 audio stream(s), quality: 48 %
Video : 361 MB, 1150 Kbps, 25.0 fps, 352*288 (4:3), MPG1 = MPEG 1 (VCD), Supported
Audio : 70 MB, 224 Kbps, 44100 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
if that helps =) -
tmpgenc dvd author! just add the mpgs and it will convert the audio to dvd compliant(48khz) and make an optional menu, author and burn.
or dvd-lab or svcd2dvd. -
is there anyway of solving this problem using tmpgenc dvd author?
"The GOP of the video is too long.
DVD-video standard requires the GOP is structured as below.
36 fields (18 frame) (NTSC)
30 fields (15 frame) (PAL)"
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
