Was wondering about something. Backups that later prove to have been written on crappy media and pixelate on the standalone, sometimes playback ok on the burner/dvd drive. If making a backup of one of these troublesomes, and it reads ok on the computer, to decent media, will you get a good copy, or will you still be transfering the errors of backup 1 ?
Anyone tried this ?
Results 1 to 9 of 9
Yes and sometimes it works and sometimes the reader will crash trying to decypher the data on the crappy disk. Best to go back to your original and re do the process.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
If it reads OK, it reads OK, and the copy will be 100% Errors are where the disc can't be read, and you can't back it up. But as jtoolman points out, it's best to backup the original again.
/Mats -
We are of course talking of the situation whereby the original is damaged/lost and no longer available etc, and to great horror and dismay you discover you backed up to a feeble quality dvd-r that pixelates on the standalone, but may get away with it on the burner.
I usually make sure that the disc is as clean as possible, then let DVDDecrypter have a go at it for a long time. Some I've had to run through a few times. I use file mode, since it's usually one or two elusive files that take the most work.
If your DVD has already been ripped, I simply do a Windows Copy/Paste to a new folder on the HDD and then burn to a new DVD with Nero. If you catch the bad DVD early, then this works fine. There's also nothing wrong with using DVD Decrypter as the first program.
If the DVD has not been ripped, then DVD Decrypter would be the first program I'd use. Keep in mind that if you get an I/O error with DVD Decrypter, chances are that the disk will not be recoverable.
Out of five disks that have gone bad, two were recoverable and three went too far. They all played on a standalone player (with freezig and pixelation) long after they were unreadable with the desktop burner (even with the latest Toshiba dual-layer "reads everything" burner).
IMO, the first time a disk freezes on a standalone player, even for a moment, it's time to burn a new copy on better media. -
"If making a backup of one of these troublesomes, and it reads ok on the computer, to decent media, will you get a good copy, or will you still be transfering the errors of backup 1 ? "
Just try it. -
Originally Posted by blinky88
Backing up files
By didikai in forum Newbie / General discussionsReplies: 19Last Post: 3rd Nov 2011, 08:17 -
Backing up HD DVD
By captainzog in forum Newbie / General discussionsReplies: 13Last Post: 21st Oct 2011, 09:49 -
Fixing troublesome mpeg files?
By Hatecrime69 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 16:41 -
Help with troublesome unpacking
By Blå_Mocka in forum ComputerReplies: 2Last Post: 29th Jan 2008, 15:34 -
Tool/download/upgrade to read troublesome DVDR?
By ecc in forum Authoring (DVD)Replies: 13Last Post: 3rd Oct 2007, 17:52
