I have some problems while converting .wav files to .ac3 using besweetgui v0.6 with besweet v1.4. I understand that in order to have a dvd compatible ac3, the ac3 must 192 to 224Kbps for surround sound and sampling rate of 48000Hz. However, my ac3 cannot be played with 48000hz settings but can be played with ower settings like 44100Hz and 32000Hz. There was no sound at all while playing the 48000Hz ac3. Can anyone Help? Any help will be greatly appreciated.
Results 1 to 16 of 16
So far, I've managed to get by (3 years soon, doing video stuff) without getting to grips with besweet. I'm sure it's extremely powerful and all, but so far, I've solved my tasks using other tools. (And I really do love command line tools!) I'm afraid I can't help you further with this.
/Mats -
In short, Besweet is nicely powerful, yet having no decent GUI sucks. BeLight is a good attempt at a simplified GUI for it, but even that has issues. It's just not a simple app to use, and depending on version, it may not have the AC3 encoder, or it will produce non-compliant AC3. Ffmpeggui is much easier to use, but with the same encoder engine as besweet, it too can sometimes produce non-compliant AC3.
The cheapest option I have found, is tmpgenc's AC3 plugin, which produces totally compliant AC3.Cheers, Jim
My DVDLab Guides -
Thanks reboot. Sad to say, i do have 'tmpgenc plus' but not 'tmpgenc ac3 plugins'. Quite broke nowadays so the idea of buying something new is totally out of the question haha.... Any GPL programs to recommend? Sound a bit stingy huh haha..
Cheers, Jim
My DVDLab Guides -
No it does not work with Plus version.
When I was born I was so shocked that I could'nt speak for 18 months. -
Buy it anyhow, it works from within DVDLab
Cheers, Jim
My DVDLab Guides -
yup i do have DVD lab but its dvd lab pro. So does the plugins work with that?
I have Audition 1.5 and Soundforge 7 on the PC side, and both work well, but what can I use on the Mac side to make AC3 files more workable?
I think Im' having hardware problems during conversions
By johnharlin in forum Video ConversionReplies: 5Last Post: 8th Mar 2011, 08:20 -
Problems with conversions
By dkritso in forum Newbie / General discussionsReplies: 4Last Post: 28th Jun 2010, 01:18 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 18:35 -
5.1 Wav to AC3
By markjwiggins in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:44
