  1. I have a DVD-burner and it works fine when I burn movies with DVD-R. However, later I decided to switch from -R to + R and tried to burn 2 disc but neither of them works.
    My DVD Burner is LiteOn 12X DVD+-R/+-RW Drive plus duel format DVD Writer. And I tried to use 2 different programs for burning: TMPGEnc DVD Author 1.6 and InterVideo WinDVD Creator 2.
    So is my DVD drive able to burn DVD+R? if so, what program should I use instead?
    By the way, that is FujiFilm DVD+R for data and video 4.7GB/120Min
  2. You have to check if you DVD Player (no writer) supports DVD+R reading.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Go to cdfreaks.com liteon forum and look for booktype setting program that will set your dvd+r to dvd-rom bitsetting when you next burn it.
  4. I had test with 2 computers and 1 dvd player.
    but why do i have to change from +R to -R? the drive supports to be able to write both +-R. Sorry, I'm a new so kind of confused.
    canada
    Its not changing the disc from + to -,its setting the +r disc to dvd-rom booktype setting so your dvd player will read it as a dvd-rom disc,you can find more info about booktype setting at cdfreaks.com and on google.
    Read here for more details on booktype setting.
    http://www.liteonit.com/ODD/Zip/BookTypeManual_e.pdf
