When I try to use Virtualdub to capture video it stops after about 15 mins. I have plenty of disk space (35 gig) and I went under the control panel and disabled all power saver features I coould find. Anybody got any ideas why. This seems to be consistant thing. Tried several times with same results.
Sounds like you are hitting the 2/4 gig limit depending on if your using fat 16/32 file system, you either have to use a more compressed codec, picvideo, etc. Or you can segment your avi file, look to forum or guides for help.
I am running Fat32 on Win98SE. I will check and see if that is the problem. I am already using picvideo codec already.
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
Help with VirtualDub 1.9.7?
By hezbag in forum Video ConversionReplies: 4Last Post: 20th Oct 2009, 05:21 -
Virtualdub help
By Rogert in forum Newbie / General discussionsReplies: 10Last Post: 2nd Sep 2009, 15:00 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Help with VIRTUALDUB Please !!!!
By spliffy in forum RestorationReplies: 10Last Post: 30th Jun 2007, 08:28
