  1. Member Sakuya's Avatar
    Dec 2002
    I have a video in 4:3 format. On this video, there are black bars at the top and bottom. At the bottom black bar, there is an occasional scrolling text message that I want to get rid of. Since it's on black, it's easy to get rid of. Can you do this in Virtualdub/MOD? I only want the overlay to be occasional.
  2. Member Sakuya's Avatar
    Dec 2002
    How do I crop? Won't it lost part of the video? Since it's only one small point in the AVI and the black bars disappear to show a standard 4:3 video halfway into the video. I don't want to crop out that video.
  3. Logoaway filter, or Region Remove filter.
    Google is your friend.
    Cheers, Jim
    My DVDLab Guides
    May 2001
    Easiest way is to crop the black on the bottom, then add a black box back. Then export your video as another AVI.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  5. the black bars disappear to show a standard 4:3 video halfway into the video
    Cropping will (obviously) crop out a portion of the video, hence my suggestion to try a filter or two.
    Cheers, Jim
    My DVDLab Guides
    May 2001
    Do the editing in segments. If you used AVISYNTH, it could be done in segments all in one pass.
