Using VDubmod 1.5.10.1. Loaded several Xvid and mpeg videos and tried to demux to .wav but nothing happened, no errors, nothing. I've done this many times and never had this problem. I set audio=full processing, video=direct stream. Tried this in Nandub, too, and same thing. I reinstalled Vdub and my codecs but nothing. I've used Vdub for a few months and never a problem. Not sure what's going on.
If I am not mistaken there is no option for "Audio" in VirtualDubMod. So you may be using VirtualDub.
In VirtualDubMod open the file. Go to Streams > Streams List. Select the audio stream and hit the Demux button.When I was born I was so shocked that I could'nt speak for 18 months. -
Another way to achieve this is to just load the AVI in Goldwave, save.
/Mats
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 23:45
