Ok, here's my situation...
I got the idea from someone to use TMPGEnc to convert my AVIs to VCDs so I could fit more on my DVD. It worked great with some files, but now some files have the extreme opposite result. While before the actual size of the files went from 241MB to 193MB with these other files the size goes from 349MB to 1178MB. YIKES! After going through all my other video files I'm having the same problem.
Any advice would be extremely appreciated! Name calling and Newbie jokes are also allowed![]()
Results 1 to 21 of 21
Welcome newb!
The only thing that affects the file size is the bitrate that was used to encode the file and the running time. Since TMPGEnc fixes the VCD bitrate at 1150 Kilobits per second then the explanation would be that some of your clips are longer in length than others.
Simple."Art is making something out of nothing and selling it." - Frank Zappa -
he difference in length is about 15-20 min. It doesn't seem to make sense to me that the length would make a difference. With one video file it goes from a larger size to a smaller size but another goes from small to extremely large. Thanks.
How do I find if that's the problem? How would I fix it? I really appreciate all the fast replies!
Use either AVICodec or GSpot (the beta v2.52 is good).Originally Posted by jonesyboy
Open the original AVI in VirtualDub.Originally Posted by jonesyboy
Save the audio to a WAV file.
Use that WAV file as the source for the audio during encoding.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Also the problem could be that some of the avi files are divx encoded. There are many "flavors" of avi. I just wish divx files stop using the .AVI extension. Many problems I've read about not been able to burn a avi file to a DVD is because the avi file is divx.
What are the audio details? Refer to jimmalenko's post above...
Xvid AVIs, on there own, aren't neccessarily the cause of the problems - it could also be the audio they contain.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
ahhh yes it is VBR where the files that work fine are CBR. Thank you. So do I just go through the instructions you just posted or is there a way I can convert it from vbr to cbr. Thanks again everyone for helping out!
Just follow what I posted and you should be OK.
Carpe diem.
http://members.dodo.net.au/~jimmalenko/ExtractAudio.htm might help you with the procedure. Then when you go into TMPGEnc, specify the AVI as your video source (it will probably automatically specify it as the audio source as well), then manually browse to your newly-created WAV file. This should fix your problems.
If in doubt, Google it. -
It says:
VirtualDUb has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 1485 ms of skew from the video stream. If this is unacceptable, decompress the *entire* audio stream to an umcompressed WAV file and recompress with a bitrate encoder. (bitrate 135.7 + 21.9 kbps) -
Load your AVI into GOLDWAVE or Adobe Audition and save as .WAV then use that.
Seems to have worked. I'm going to work nowbut will post the final results when I get back tomorrow.
Thanks a lot! -
It worked out very well in this case, but I still have files that don't seem to follow suit. They are already cbr audio and yet I seem to be having the same problem.
Use VirtualDub to scan for bad frames, and then fix the frame(s) yourself - i.e. delete video and associated audio. That's a possible cause...
Carpe diem.
Idiot's Guide to Encoding
By sharpfocus in forum Newbie / General discussionsReplies: 4Last Post: 11th Sep 2011, 20:59 -
An idiot and a video_ts folder...
By CitizenErased in forum Newbie / General discussionsReplies: 11Last Post: 24th Jan 2011, 17:00 -
have mp4 (h264/aac), need m2ts - help an idiot out please :/
By namurt in forum Video ConversionReplies: 8Last Post: 13th Nov 2009, 15:18 -
Mozilla is becoming *VERY* idiot-friendly :-(
By Midzuki in forum Off topicReplies: 10Last Post: 25th May 2008, 17:12 -
Nero help for newbie IDIOT
By bbassboat in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2008, 18:32
