I just transferred my digital 8 from my sony to my computer and burned to dvd and the picture quality is not good at all compared to the original tape. I used intervideo's windvd cinema platinum 2. Any advice please. thanks
try many tooooooooooooooools...one method:
"capture" the dv with windv
convert to dvd mpeg with tmpgenc plus, mainconcept mpeg encoder, cce basic or canopus procoder
author to a dvd with tmpgenc dvd author -
are you using USB on transfering ur movie to ur pc?? am using firewire on transfering & pinnacle studio 8 for editing/rendering/burning, got a good quality vids
what format did you capture to on your hard drive? dv .avi's, or on-the-fly mpeg encoding? What are the attributes of your captured videos?
what are the attributes of your project/disc (PAL or NTSC, mpeg-1 or mpeg-2, resolution, bitrate, audio type, etc...)?George -
I am new to this but I beleive it is avi, windvd captues the video and allows you to author and burn. The problems I am having is that the video quality is very bad and when I try to create chapters the chapters have no audio, I am now using windv but I see that it split my captured video into 5 files.
Transferring legal DVD to digital format for flash drive viewing
By tryingcake in forum Video ConversionReplies: 17Last Post: 20th Feb 2012, 04:10 -
File size (quality issue) transferring video
By subba in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Oct 2009, 06:53 -
DV capture quality sucks
By cooldude859 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 36Last Post: 28th May 2008, 16:07 -
Transferring Mini DV to DVD without loss of quality
By khalidizzeldin in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2008, 07:10 -
Transferring raw video from Sony miniDV to PC
By TahoeTexan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 16th Apr 2008, 19:01
