I am looking dvd authoring software that will allow me to burn a dvd disc using MPEG files that I have Edited, without a menu. Some are Pal re-edits to be played back in NTSC.
There is only one piece of DVD authoring software worth talking about: DVD-lab PRO
TMPGEnc DVD Author, as previously mentioned. Smooth as butter. Just check the "No Menu" option.
Thank you very much for your help. TMPGEnc DVD Author, worked great. All the other software I was using, caused audio skips or drop outs.
Encore DVD Menu Authoring
By montgal in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th Apr 2012, 23:24 -
Authoring DVD without a menu?
By Humptydank in forum Authoring (DVD)Replies: 6Last Post: 29th Mar 2010, 16:55 -
how to keep original menu and not re-encode files by dvd authoring
By deejay.2001 in forum Authoring (DVD)Replies: 8Last Post: 1st Sep 2008, 02:08 -
dvd authoring with hidden menu
By VeryNewbie in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2007, 03:21 -
DVD Authoring: Menu Creation, Encoding, etc
By kerpal in forum Authoring (DVD)Replies: 7Last Post: 20th May 2007, 18:27
