hi, i used DVD Lab to build a dvd with portuguese subtitles,one audio english track and with chaptor extractor ,i imported the txt track to create de chaptors.So far so good.then i update the original ifo with the authored ifo in ifoupdate.then i watched the movie but no chaptors.What i have to do to insert just the chaptors or to view what's wrong with the ifo.Can pgcedit deal with the question??Please help me to fix this.
Why ifoupdating? Are you trying to add original DVD's menu to your DVD after all? Anyway, did you remember to copy the vts_01_1.vob etc (made by DVD-lab) over the originals as last step?
It might be necessary to get rid of all irrelevant lines of chapter file created with chapter extractor, leaving only the essential text (times) to make it work. I have experienced such problem in the past. -
Probably it cannot be achieved this way.
Here is a guide https://www.videohelp.com/~r0lZ/pgcedit/third_party/blutach/adding_menus_to_dvd_shrink_...hored_dvds.htm
However if DVD-lab is your favourite method of reauthoring DVDs, you could have extracted the menu material with the use of a tool like vobrator (open vts_01_0.vob, select desired menus and save). Then insert the extracted menu clip to dvd-lab and add the appropriate links, while building your custom dvd.
Help with IfoUpdate
By melany in forum EditingReplies: 2Last Post: 17th Oct 2009, 10:58 -
dvd lab pro 2
By m baqar in forum Authoring (DVD)Replies: 6Last Post: 7th May 2008, 02:39 -
dvd-lab...no audio
By sylvester243 in forum Authoring (DVD)Replies: 2Last Post: 11th Jan 2008, 03:00 -
DVD Lab 2 error
By XL3/\/7 in forum Authoring (DVD)Replies: 4Last Post: 3rd Jun 2007, 07:54 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 08:52
