So, I bought 200 TY non-hub white printables from shop4tech the other day. VERY happy with the burn quality of the discs, but printing labels onto the surface with my R200 is terrible! The surface of the TYs is kind of bumpy, not smooth at all. So when the R200 prints, it tends to lose resolution and the final result doesn't have a "clean" finished look to it. I would try spraying the disc, but I don't think that will help at all.
Any one else have similar experiences? I'm sure it's not the R200's fault, because as an experiment, I tried printing the same label onto a non-TY printable disc and the result was a crisp, shiny, high-res DVD. There's something wrong with the TYs ...
Are these real TY discs? I use the hub printable ones from Rima and love them.
I had the same problem, but I solved it by changing the contrast from "0" to "25". Once that was done they printed just fine.
My personal advice:
Play with your settings and you will be happy.
You are right to state that TY printing surface is a little more rough than, let's say, ritek. That does not mean that the final result is less good.
Play with the media type settings, try premium semi-gloss, try photo RPM with or without microweave per example. You should find a match.
I am always able to get a good print from almost any surface, but I have to change parameters.
Happy printing!
looking for silver hub printable DVD media
By PharmBoy in forum MediaReplies: 6Last Post: 30th May 2008, 06:31 -
Glossy hub printable DVD+R
By PharmBoy in forum MediaReplies: 9Last Post: 27th May 2008, 09:06 -
TY R47WPP600SK -- hub printable or not?
By spiffy in forum MediaReplies: 6Last Post: 12th Mar 2008, 22:03 -
Dual Layer hub printable media??
By garstan in forum MediaReplies: 4Last Post: 21st Oct 2007, 15:50 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 11:29
