  1. anyone can share some info. on how to convert VOB files to avi or mpg.
    TIA
    Sep 2003
    What do you plan to do with them? If you change the ending of the file from vob to mpg, they will essentailly be mpg files.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Not at all. They will still be VOB files. Changing the name (and/or extension) of a file doesn't alter what it is (but might fool some apps into opening what it otherwise (possibly for a good reason) would refuse.)
    /Mats
    Sep 2003
    Have you tried it? If you change the file extension to mpg, the file will behave exactly like an mpeg. You can then load it into an mpeg only editor or authoring program.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I don't have to try things like this - I know them. Do you change if you change your name? Does a Word file become an Excel spreadsheet if you change the extension from .doc to .xls?
    /Mats
  6. Changing the extension of a file may cause the programs which open it to intrepret the file in a different way - possibly incorrectly. But surely the contents do not change.
    This could be suggested to Microsoft. We could do away with the "Save As ..." option.
    When I was born I was so shocked that I could'nt speak for 18 months.
